Activity Forums VEGAS Pro DVD Arcnitect – Blu-ray issue
  • DVD Arcnitect – Blu-ray issue
    Posted by Rick Hughes on October 23, 2015 at 12:56 pm
    I have Movie Studio Platinum 12 and DVD Architect 5.0
    Both working fine for DVD
    Now starting out on Blu-ray projcets …..
    Under help for DVD architect it states that I can create Blu-ray discs … and simply I can go to ‘file > make Blu-ray disc’
    However when I go to file .. it does not give a Blu-ray disc option ? only DVD
    The wording everywhere says DVD … no mention of Blu-ray ……. is there an upgrade or something I need. ?
    In the icons at top of screen .. only ‘make DVD’ again nothing for ‘make Blu-ray’
    I have tried ‘get update’ and it tells me I am on latest version.
    Is there a config or patch required ?
    Rick Hughes replied 10 years, 11 months ago 4 Members · 9 Replies
  • 9 Replies
  • Jorma Nippala
    October 23, 2015 at 1:38 pm
    [Rick Hughes] “I have Movie Studio Platinum 12 and DVD Architect 5.0
    Is there a config or patch required ?”
    No. Create a Blu-ray project from File > New and choose Blu-ray Disc format.
  • Rick Hughes
    October 23, 2015 at 2:36 pm
    I was looking in help file it shows:
    and following those instructions … under file:
    No option for Blu-ray there, hence my Q. is there something wrong with my version.
    I did try your steps of File new > Single movie > Bluray that does work …. but still concerning about the points above.
  • Jorma Nippala
    October 23, 2015 at 3:01 pm
    [Rick Hughes] “I did try your steps of File new > Single movie > Bluray that does work …. but still concerning about the points above.”
    Do you mean you don’t see “Make Blu-ray Disc” on the Toolbar and under File after you tried the steps?
  • Rick Hughes
    October 23, 2015 at 3:26 pm
    I see only make DVD … screen grab was in previous post
  • Jorma Nippala
    October 23, 2015 at 3:57 pm
    Yes I did notice your previous screengrab.
    This is what you should see after you followed the steps.
    My screengrab is from DVD AS 5 build 157 (not the latest). Possibly a buggy build or a faulty install, if you don’t get the BD option and a user error is ruled out.
  • John Rofrano
    October 23, 2015 at 11:08 pm
    You will not see the Make Bu-ray Disc option in a DVD project. You must first create a Blu-ray project, or change your DVD project to a Blu-ray project. That is the only way to get the Make Blu-ray Disc option because it only appears in Blu-ray projects.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Rick Hughes
    October 23, 2015 at 11:10 pm
    Thanks for the explanation.
  • John Laird
    October 24, 2015 at 2:09 am
    You can also go to the Tools menu in Vegas and create a Blue-ray disk right from Vegas. The caveat here is It won’t have a menu, but it will play as soon as you put it in the Blue-Ray Player.
    John
  • Rick Hughes
    October 24, 2015 at 8:41 am
    …in this case I need to put menus in place.
