DVD Architecture
Posted by Dan Estes on August 18, 2007 at 5:21 pmI just upgraded Vegas 6.0 & DVD Architecture 3.0 to Vegas 7.0 & DVD Architecture 4.0. I am having a problem viewing the burned DVD’s correctly. The video and audio seem to skip frames. Although, when I go to PREVIEW within DVD Architecture the video and audio plays back without any indication of a problem. The only change from the default settings is I am using the NTSC widescreen (720 x 480)option. NOTE: The rendered file from Vegas is NTSC widescreen (720 x 480).
I would appreciate any assistance.
Thanks.
Dan Estes replied 19 years, 1 month ago 4 Members · 8 Replies -
Edward Troxel
August 18, 2007 at 7:34 pm -
Dan Estes
August 18, 2007 at 9:32 pmI have the bitrate set to 8.2. Also, I am using the same CD/DVD burner as I did using Vegas 6.0 & DVD Architecture 3.0. The burner does burn cd’s and DVD’s, but I’m having difficulty with burning successfully using the new version of DVD Architecture 4.0.
NOTE: I was able to burn a DVD using DVD Architecture on another computer.
– Still would appreciate some additional sugestions.
Thanks again.
Terje A. bergesen
August 19, 2007 at 9:36 amThings to look at
1/ Bitrate, 8.2 is just a little higher than I would burn. I have noticed that some players have problems playing DVD-R and DVD+R disks if the bitrate is around max.
2/ Media. Get Taiyo Yuden or other quality media. There is a huge difference in playback quality between good and bad media.
3/ Burn speed. Burn as slow as your burner will allow. This usually yields higher quality burns.
4/ Hardware. If you have had your DVD burner for a while, it may be doing poorly. I have had burners that worked great when I got them but 12-18 months down the line and I get bad burns. I just got my self a new DVD burner just because of this. Don’t know why his is, but I am guessing things like dust and dirt can have an effect on the burners ability to properly burn disks.
Terje A. Bergesen : https://terje.bergesen.info/ -
Dan Estes
August 19, 2007 at 10:05 amYou are probably right regarding the age of the burner. I will probably have to replace it and get a new one.
Thanks.
Dan Estes
August 19, 2007 at 6:28 pmOne more question. After attempting to burn seven DVD’s unsuccessfully, I noticed all DVD’s skipped at the same locations and increments on playback. Would this still indicate the burner being a hardware problem?
I am going to uninstall DVD architecture 4.0 and re-install 3.0 and see if I have the same problem. If this doesn’t work then I will assume the burner is a problem. NOTE: It was okay before I instaled 4.0, but things can happen. -
Dan Estes
August 20, 2007 at 1:07 amI re-installed DVD Architecture 3.0 and burned a DVD. Everything is working well now. There must be some kind of compatability between 4.0 and my burner. Also, I have the most recent firmware for my burner.
Oh well, at least I’m back to making DVD’s.
Valvehead
August 20, 2007 at 7:31 amYou might also try using a different program to burn the prepared files. I use Nero v6 because it gives me more burning options. I’ve also read that ImgBurn is good.
