Activity › Forums › VEGAS Pro › DVD Architect v5.2 audio glitch at end of disc
  • DVD Architect v5.2 audio glitch at end of disc
    Posted by David Dusman on November 6, 2011 at 11:32 pm
    I have just finished a dvd project, and every time I burn a disc to test, I get a pop in the audio at the end of the file, just as it ends and before it returns to the start menu. I’m using one complete file with chapter markers in it, and a video under the main menu. The audio track is PCM 48K 16 bit. I’ve checked the audio file, re-rendered it, listend to it in a different program and it is clean. It’s a very disturbing pop in the left channel. I’ve played the discs in 2 players with the same result.
    Any thoughts are appreciated!
    Stephen Crye replied 14 years, 10 months ago 3 Members · 2 Replies
  • Ted Snow
    November 7, 2011 at 3:23 am
    Try rendering the video without the audio and render the audio as an AC3 file. Render them both into the same directory with the same name. This way DVDA doesn’t have to re-render the audio for the DVD.
    Not sure why you’d be getting a pop but you might try this and see if you get better results.
    ASUS P8P67 Deluxe MB
    EVGA GeForce GTX 560 Ti 1 GB DDR 5
    Intel i7 2600k 3.4 Ghz
    Corsair HX750 power supply
    Two Seagate Barracuda 500g SATA III drives
    16 Gig G.Skill Ripjaws DDR3 1600
    Canopus ACEDVio card
    Thermaltake V9 BlacX Edition case
    Xigmatek Dark Knight CPU Cooler
    Win 7 Pro
    VEGAS 8.0
    VEGAS 11.0 32 & 64 bit
    Sony VX2100
    Sony HVR-Z7U
    Alesis HD24
  • Stephen Crye
    November 8, 2011 at 8:39 pm
    Make sure you have at least build 133 of DVDA 5.2 .
    Steve
    Win7 Pro X64 on Dell T3400 MultiTB SATA 8 GB RAM Vegas 10e x64 DVDA 5.2 Sony HDR-CX550V
