Activity › Forums › DVD Authoring › DVD Architect – Slideshow
Posted by Diane Sosnoski on May 3, 2010 at 3:45 pmI want to create (my first) slide show with a music track using DVD Architect. I’ll be scanning old slides as well as still photos of different sizes.
When I convert the scans in Photo Shop, what resolution should I use?
Also, should I try and make all the photos the same size?Thanks for any help,
DianeRoman Melekh replied 16 years, 3 months ago 2 Members · 8 Replies -
Diane Sosnoski
May 3, 2010 at 11:59 pmI should have also said that I’ll be projecting this onto a large screen, rather than showing it on a laptop.
Diane Sosnoski
May 4, 2010 at 5:28 pmIt’s going to be 4.9 NTSC. I’m scanning old slides and prints and the final DVD will be projected on a wall or screen with a music soundtrack.
Roman Melekh
May 4, 2010 at 6:43 pmOk
This is copy from Scenarist SD User Guide:
Still images for 16:9 Widescreen
When creating still images for a 16:9 Widescreen project, special steps are required to ensure that the images are displayed correctly. You should create the images initially at a resolution of 960 x 480 for NTSC and 960 x 576 for PAL.Then, just before importing the image into Scenarist SD, resize the image to 720 x 480 for NTSC and 720 x 576 for PAL, therefore recreating the anamorphic squeezing effect that is performed on widescreen video. When the content is played back, it will be stretched back to its original widescreen aspect ratio.100% this work with DVD Architect 🙂
! after resizing images to 720*480, you’ll need to apply 0.5 pix vertical blur to reduce flickering
OR may be….you can use software for creating slide-shows?
ProShow, Imaginate etc – create video file with transitions, effects and titles? -
Diane Sosnoski
May 4, 2010 at 9:41 pmThanks for your response, but it’s not a Widescreen project. I accidentally typed 4.9 instead of 4.3 in my response.
Sorry for the confusion. Should the resolution be 72DPI?Thanks
Diane Sosnoski
May 5, 2010 at 10:59 pmOK, thanks Roman,
I’m not sure when I adjust the color space but maybe that will become clear as I proceed. I’m intending to scan the slides, bring them into Photo Shop for color correction, resizing, etc. then put them on the time line in DVD Architect which has a chapter on “Creating a Picture Compilation” and “Generating slideshow animation” but no info on how to prepare the stills.
I can’t afford to buy any new specialized software right now, so I’m hoping DVD Workshop will do the trick. -
Roman Melekh
May 6, 2010 at 5:28 amPhotoshop’s corrections – this is Levels (16.235) and Blur (0.5 pix)
