Activity Forums VEGAS Pro DVD Architect settings
  • DVD Architect settings
    Posted by Kevin Mccarthy on September 10, 2011 at 6:03 pm
    I’m sorry to be a bother, but I usually do “single movie” DVD’s. Now I need to do a DVD of approx 20 clips, or markers, that can be viewed in any order. I know I need to use the menue based template, but I do not want the DVD to “play through” all cuts. I need to have it stop after each segment and then go to the next segment when pressing play and, if needed to go to a menu to select a specific segment either before or after the segment that just played.
    Now, here is the kicker, this is for a Court presentation where they only use Window Media Player to play into ther viewing system. I don’t know if there is anything unique about WMP, but that is a mandate.
    I have tried to make sense out of the properties section in DVD-A and for whatever reason, I brain locking on it.
    I sure could use some help. Thanks in advance!
    KEvin
    Dave Lozinski replied 14 years, 11 months ago 2 Members · 1 Reply
  • Dave Lozinski
    September 12, 2011 at 1:13 am
    I know there is a “play list” option in DVD Architect Pro. Have you checked that out?
    Also, you can put all 20 clips on a DVD menu. There is an option in DVD Architect when a clip is finished playing to either continue on to the next clip or return to the main menu.
    Hope this gets you going in the right direction.
    https://www.davelozinski.com
    https://www.davelozinski.com/DemoReel/
