DVD Architect Says My MPEG is Non Compliant
Posted by Casey Menninger on November 23, 2011 at 12:02 amHello,
I created an MPEG file with Sony Vegas Pro 10. I used one of the DVD Architect MainConcept templates. 720 by 480, 24p frames per second.
However, when I try to author/burn the file to DVD via DVD Architect 4.5, it says the file is not compliant and must be recompressed. Obviously, I don’t want to do that.
What am I doing wrong? I want to make the disc 24p due to the source footage, but I can change that, I suppose, if DVD Architect won’t accept that format.
Casey Menninger replied 14 years, 10 months ago 3 Members · 9 Replies -
John Rofrano
November 23, 2011 at 12:45 amDid you change anything about the template? If you did, this is probably the reason it’s non-compliant. I’ve never had DVD Architect reject a template that was unchanged.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Casey Menninger
November 23, 2011 at 1:03 amHi John,
I don’t think I changed anything…Video: 24 fps, 720×480 Progressive, YUV, 8 Mbps
Pixel Aspect Ratio: 1.212I might have changed the setting that defaults to 9 bits to 10 (8, 9, or 10 are the choices)
Casey Menninger
November 23, 2011 at 1:09 amFor what it’s worth, this is what pops up in DVD Architect 4.5 about “compliant” NTSCvideo files. It doesn’t say 24p is compliant, is that the problem?
NTSC MPEG video (.m2p, .mp2, .mpg, .mpeg)
If you’re using the MainConcept MPEG-2 encoder in Vegas Movie Studio, use the DVD Architect NTSC video stream or DVD Architect NTSC Widescreen video stream template to render your video stream (you’ll need to render your audio stream separately according to the parameters listed in the AC-3 audio or PCM audio headings).Aspect ratio and frame size:
Aspect ratio
Frame size4:3
720×4804:3
704×4804:3
352×4804:3
352×24016:9
720×48016:9
704×480Frame rate: 29.97 fps
Maximum GOP (group of pictures): 36
Maximum bit rate: 9.8 Mbps
No low delay
Mike Kujbida
November 23, 2011 at 3:00 amYUV is why it’s not compliant.
A compliant DVD render requires MPEG-2 for video and AC-3 for audio.
Use the DVD Architect 24p NTSC Widescreen video stream template and things should work out as expected. -
Casey Menninger
November 23, 2011 at 3:39 amMike,
As far as I can see, the template you mention is also YUV, per the specs in the drop down box…
John Rofrano
November 23, 2011 at 1:14 pm[Casey Menninger] “I might have changed the setting that defaults to 9 bits to 10 (8, 9, or 10 are the choices)”
10 is non-compliant. The DVD spec only goes up to 9.5 and I wouldn’t burn anything greater than 9 if you want most players to be able to play it.
Try using the template shipped by Sony without changing ANYTHING.
~jr
Casey Menninger
November 23, 2011 at 2:48 pmHi John,
It must be something with DVD Architect. No matter what untouched, default 24p template I use, DVD Architect says the video stream is not compliant and must be recompressed. It doesn’t do this if I use a 30 fps NTSC template.
Casey
