Activity Forums DVD Authoring DVD Architect quicktime mov error
  • DVD Architect quicktime mov error
    Posted by Rafael Otero on February 6, 2009 at 3:43 pm
    I am trying to build a DVD using some Quicktime mov files my customer provided.
    When I start a new project using Architect, I tell it that it is a single movie, and it prompts me to look for the file. When I select the file it gives me the following error:
    The Selected file is not of the required type.
    When I try to import the file into DVD architect by dragging the file into the project window, I get the following error:
    An error occurred during this command (Id: 6612)
    An error occurred while opening a codec.
    What does this mean? I am not sure how my customer published the file. I know it is a quicktime mov file and I have use quicktime files with DVD architect in past. Why do you think his is not working? Is there a specific setting I need to tell my customer he needs to use when publishing his files?
    Thank you for your help.
    Rafa.
    Kert replied 17 years, 4 months ago 2 Members · 1 Reply
  • Kert
    April 16, 2009 at 5:44 am
    You can import the .mov file into Vegas, then render it to MPG2 and .AC3 and then import both into DVDA.
