Activity › Forums › VEGAS Pro › DVD Architect problem
  • DVD Architect problem
    Posted by Thomas Quinn on July 2, 2005 at 10:23 pm
    Sorry for troubleing the list again with what may be a trivial question to some but I am fumbeling along as best as I can.
    In DVD Architect when I go to make DVD and go to burn and press next I get the message the selected path is not valid the path must contain a VIDEO TS and AUDIO TS folder and may not contain any other files or folders
    How do I go about making the required folders
    Thomas Q
    Dan Jones replied 16 years, 9 months ago 4 Members · 3 Replies
  • Michael Morone
    July 2, 2005 at 11:13 pm
    I see two possible reasons for this:
    1–It is possible that you did not “Prepare” the project before you selected “Burn”. Preparing the project creates a folder and files. When you choose to burn the DVD, DVD Architect looks to these files (VIDEO TS and AUDIO TS folders with video and audio files) to burn the DVD.
    2–If you already Prepared the project, it is possible that the folder you are directing DVD Architect to look at is not where the prepared files are located. Immediately after you click “Make DVD” and “Burn” you must click “Browse” and choose the correct “Prepared folder”, which contains the VIDEO TS and AUDIO TS folders for your project. It might be called something like “My DVD” unless you changed the name to something else. If you did Prepare the project, but do not remember, or do not know where the files were prepared too, look under the “Burning” tab located in “Prefrences” under “Options”. The Default prepare folder is listed. If that is not the folder, you can search your computer for folders with the names “VIDEO_TS” and “AUDIO_TS”.
    I hope this helps,
    Michael M.
  • Allen Zagel
    July 3, 2005 at 12:38 pm
    What you need to do in simple terms is before you do your DVD project, right click on the start menu and click explore. Then go to one of your hard drives and create a empty folder with a name you’ll remember. Don’t put anything in that folder! Not even the VIDEO TS and AUDIO TS folders as DVDA will create them for you.
    This is a simple thing that most of us forget to do sometimes, and then have problems as you’re having.
    Allen
    My web site features;
    China, China Railways and music.
    https://www.azagel.com
    Video site;
    https://www.asxmediaproductions.com
  • Dan Jones
    December 24, 2009 at 4:45 am
    I am having the same problem and neither soultion worked for me. Have you ever found a fix?
