Activity Forums DVD Authoring DVD Architect Pro 5
  • DVD Architect Pro 5
    Posted by Tony Smith on July 6, 2010 at 1:19 pm
    Hello, I’ve just started using DVD Architect Pro 5 under Windows 7. So far it works fine except that having burned the first disc successfully, when trying immediately to burn another it appears to do the burning but then ejects the disc with the message that it is an incompatible disc without completing the burn.
    Does anyone have any idea what is going wrong?
    Thanks for any help.
    Tony Smith
    Tony Smith replied 16 years, 1 month ago 2 Members · 2 Replies
  • Dave Lozinski
    July 26, 2010 at 2:14 am
    Out of curiosity, after you burn the first disc, have you tried saying “no” to burning a second disc? Then returning to the project, going through the prepare/burn process again, and then seeing if it does it successfully?
    https://www.davelozinski.com
  • Tony Smith
    July 26, 2010 at 10:09 am
    Hi Dave,
    Thanks for the reply. Yes I did try a while ago as you suggest and it still caused problems. In the end, because I only use the software in a very simple way, I went back to version 4.5 and it worked fine.
    I suspect there was an installation glitch with version 5 which I will look into in due course when time permits.
    Once again thanks for your reply.
    Tony Smith
