Activity Forums DVD Authoring DVD Architect Playback Issue on Single Title
  • DVD Architect Playback Issue on Single Title
    Posted by Steve Mason on September 14, 2015 at 10:42 pm
    Hello,
    I authored a DL disc in DVDA 5.2; all titles, menus, etc. work flawlessly, with the exception of one title. For whatever reason I only have this issue with one player which is about 5 years old and fairly high-end as players go (part of home theater system.
    I am puzzled as to why this one title is causing the player to freeze when all the others play fine.
    Any suggestions would be greatly appreciated.
    Daniel Ludwig replied 11 years ago 2 Members · 1 Reply
  • Daniel Ludwig
    September 16, 2015 at 6:12 pm
    Hi Steve,
    I´m not an DVDArchitect-user, but DVD-9 in general has several problems with standalone-players, so there´s nearly no doubt that it´s a DVD-/+R-media-problem.
    I have seen many problems on several players especially with the layerbreak-position and the content that comes afterwards (meaning which lays on layer1).
    1. layerbreak-position
    if you did not create a dedicated disc-image before burning, there might be the problem with the layerbreak-position. most burning-apps will set the layerbreak-postion at the real physical end of layer0, which is wrong in most cases. In case you´ve got a disc-image, you should be ready to burn the data.
    2. reflection of layer1 of the optical media.
    all DVD+/-R-media have a different reflection (lower reflection-output) from the disc, and especially on the 2nd layer. it could result on a problem while re-focussing on the 2nd layer or reading the data.
    3. bitrate
    high bitrate could also result in playback-issues. it´s highly recomended to use lower bitrates.you should use a max. bitrate of 8,5Mbit/s or less.
    should this DVD be replicated?
    danny
