Activity Forums VEGAS Pro DVD Architect not seeing my burner
  • DVD Architect not seeing my burner
    Posted by Dave Petteruto on May 28, 2011 at 9:02 pm
    Hello Again, I’m trying to burn a DVD using DVD Architect Pro 5.2 and my burner (see below) is not showing up in the device list. The only option is for an ISO file.
    It’s a brand new computer, Windows 7 64 bit, fresh software install. On a side note the computer came with a limited version of Nero and the burner does show up in Nero.
    Burner:
    LG Electronics 10X Internal SATA Blu-ray Disc Rewriter WH10LS30
    Dave P.
    Jorma Nippala replied 11 years, 4 months ago 13 Members · 25 Replies
  • 25 Replies
  • Nigel O’neill
    May 29, 2011 at 12:33 am
    Try reinstalling DVDA
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Dave Petteruto
    May 29, 2011 at 3:15 pm
    Hi Nigel,
    I reinstalled DVDA and it still does not see the burner.
    I have also discovered that Vegas 10 64bit and Vegas 7 32bit do not see the burner either. However both Vegas versions mentioned above do recognize the burner under the “Import_Camcorder DVD Disc…”
    Nero and the Windows DVD burning software both see the burner.
    Any thoughts?
    Thanks.
    Dave
    Intel I7 950, 12GB RAM, NVIDIA GeForce GTX 460 SE, Vegas Pro 10 (32bit/64bit), Windows 7 Pro 64bit, LG WH10LS30 10X Bluray Burner.
  • Stephen Mann
    May 29, 2011 at 8:29 pm
    Does *windows* see the burner?
    DVDA itself does not “see” hardware, but it only has access to whatever hardware that Windows can communicate with.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Dave Petteruto
    May 29, 2011 at 8:43 pm
    [Stephen Mann] “Does *windows* see the burner?
    DVDA itself does not “see” hardware, but it only has access to whatever hardware that Windows can communicate with.”
    The burner is listed as drive E. Nero and Windows DVD maker both can burn to it. It shows up in the device manager.
    I checked and the burner seems to have the most recent firmware.
    Very strange.
    Dave P.
  • Nigel O’neill
    May 30, 2011 at 2:53 am
    Dave
    A search on Google suggests re-installing any drivers that came with the burner, but also implied that the burner was added later. You may also investigate updating the firmware on the burner itself.
    I also came across this on the SCS website:
    I am using a motherboard with an nForce chipset, and my Sony Creative Software program does not see my DVD or CD drive. How do I fix this?
    If you are having problems with drive detection in our software, make sure you have the latest nForce chipset drivers provided by NVIDIA. Some motherboard manufacturers only provide older versions of the drivers on their own websites. Download the newest drivers directly from NVIDIA to correct the problem. If the software is still not detecting the drive please contact Customer Service for further help.
    A workaround could be just to Prepare your DVD instead of trying to Burn it, then use Nero to burn the DVD using its Burn DVD Video Files function. You only need the files in the VIDEO_TS folder that DVDA creates.
  • Stephen Crye
    May 30, 2011 at 5:23 pm
    I Had this exact problem with nearly the same exact LG Bluray burner. Below is what I finally did to fix it, along with the suggestion from Sony support that did NOT fix it. Hope this helps,
    Steve
    First, I must complain about how ridiculously hard Sony makes the process of asking a question! Every damn time, I have to fill out this crappy form, putting in the SAME DAMN INFO that you ought to be saving in a database with my account!!! It is HORRIBLE!!! No way to just re-open a “solved” question – all I’m trying to do is provide YOU with feedback. But oh, no, Sony won’t provide a “reopen” button – that would make it too easy for shmucks – er customers – to ask questions!!!
    Below is the original suggestion, which does not work, not with Vegas 9.0 or 10.0, DVD arch 5.0 or 5.2.
    I finally figured it out myself. All one has to do is uncheck “use legacy disk drivers”.
    Disgusted,
    Steve
    Hi Stephen,
    Vegas and DVD Architect do not detect my new LG BH10LS30 drive
    Thank you for contacting Sony Creative Software. First, I apologize for the unusually long delay in responding to you. Our new Vegas Pro 10 has been well-received and as such, a high number of people are coming to us for support on this product.
    Please try the following:
    1. In Vegas, Navigate to Options – Preferences – CD Settings and select the option for Skip Drive Database, Auto-detect drive capabilities. Click Apply then OK. Close Vegas. Restart your system. Open Vegas again.
    2. Is the drive Recognized in Vegas at this point? If it does, try the following in DVD Architect Pro 5.0
    3. Navigate to Options – Preferences – General and look for the same option: Skip Drive Database, Auto-detect drive capabilities. Place a check mark next to this item and then select Apply and then OK. Close DVD Architect. Restart your system.
    Please respond back with your System info if you should continue to experience problems. Please provide us with your system information to help us further research your issue.
    Go to Start > Programs > Accessories > System Tools > System Information.
    Click on File > Export.
    Enter a File Name and Choose your Save in Location and Click Save.
    Select a destination to save the file (like your Desktop) and enter a name for the file (i.e., si.txt).
    To attach a file to this incident: Scroll to the bottom of the webpage, Click “Browse”, locate the file, and then click “Open”
    When you are ready, select the “Submit Update to Question” button.
    If you still have a follow-up question on this particular incident, please feel free to update it. If you have a completely different question, please create a new incident.
  • Dave Petteruto
    May 30, 2011 at 5:48 pm
    Steve—BINGO. Unchecked “use legacy drivers”
    Just for the heck of it I’m going to try the Sony suggestion you were give to see if it works for me.
    Dave P.
  • Dave Petteruto
    May 30, 2011 at 6:10 pm
    Steve–FYI
    [Dave Petteruto] “Just for the heck of it I’m going to try the Sony suggestion you were give to see if it works for me.”
    Sony’s fix did not work. I put in a help ticket a couple of days ago. It will be interesting to see their suggested answer to this issue.
    Thanks very much for you help Steve.
    Dave P.
  • Stephen Crye
    May 30, 2011 at 9:48 pm
    Heh – glad to have helped. I agonized over this for weeks before I hit on it. Those LG burners are sweet, eh?
  • Bob Qualls
    June 16, 2011 at 2:02 pm
    Hi Steve
    I am new to this forum but I am experiencing the same problem described in this thread.
    Vegas and DVD Architect do not detect my new LG BH10LS30 drive.
    You say to uncheck the “use legacy disk driver”
    How and where do I find this option?
    thanks for any help you can provide.
    Bob Q.
Page 1 of 3
