Activity Forums VEGAS Pro DVD Architect Menu loops
  • DVD Architect Menu loops
    Posted by Tony Archer on July 24, 2008 at 4:49 am
    I am new to Sony’s DVD Architect and was trying to simply create a menu which has clip-buttons looping through a short section of video. ie Animated clip buttons.
    I figured out how to animate the button but it doesn’t loop back to the start, it just stops when the clip is done playing.
    Also, I would assume the same would be true if I made the entire background of the menu be a video.
    Anyone know the solution? I assume this is a fairly standard effect to want to achieve
    Tony Archer replied 18 years, 2 months ago 2 Members · 2 Replies
  • Jeremy Rasnic
    July 24, 2008 at 1:31 pm
    Under “Page Properties” check the “Loop” box; it should be right underneath the Menu Length. I don’t know what version you are using but that option should be there.
    j razz
  • Tony Archer
    July 24, 2008 at 2:55 pm
    Thank you!
    I am using 4.5 and the specific setting was to change the “End Action” Command to “Loop”
