Activity Forums VEGAS Pro DVD Architect is re-optimizing my ac3 audio track
  • DVD Architect is re-optimizing my ac3 audio track
    Posted by Mary Waitrovich on January 30, 2007 at 5:18 pm
    I rendered my video in vegas twice, once as .mpg2 with “DVDA NTSC video stream” template and once as .ac3 with the “default” template, as I have done in the past. However, now DVDA gives me a warning that the audio track will be recompressed. When I go to File>Optimize, it says the audio format is .ac3 stereo and I can’t change it.
    What do I need to do to avoid re-compressing my audio track?
    thanks in advance,
    Mary Waitrovich
    UW-Madison
    Gary Kleiner replied 19 years, 7 months ago 3 Members · 6 Replies
  • Gary Kleiner
    January 30, 2007 at 8:08 pm
    On the botttom right of the optomize window are the default settings for video and audio. If you have the audio set to PCM, it’s going to recompress your AC-3.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Mary Waitrovich
    January 31, 2007 at 2:13 pm
    That’s what’s so puzzling, Gary. I do have the drop-down in the bottom right corner of the optimize window set to ac3 not PCM. I still get the recompress warning. Any thoughts?
  • George Wing
    January 31, 2007 at 3:26 pm
    Does your mpeg file contain audio (either using the CUSTOM button to render with audio, or perhaps using one of the other templates by mistake)?
    Try going to the timeline for the Title, and replace the existing audio track with the AC3 audio track.
  • Mary Waitrovich
    January 31, 2007 at 5:13 pm
    Thanks, but I have double checked all this. Fortunately, the double encoding doesn’t seem to have an audible effect on the audio track.
    -Mary
  • Mary Waitrovich
    January 31, 2007 at 5:39 pm
    Okay…upon TRIPLE checking, I realized I had encoded as an “.aa3” rather than “.ac3”
    problem solved!
  • Gary Kleiner
    January 31, 2007 at 7:06 pm
    Computers…. they’re so picky :-0
    Gary Kleiner
