Activity Forums VEGAS Pro DVD Architect – File Saving/Back Up
  • DVD Architect – File Saving/Back Up
    Posted by Miss Moo on December 4, 2005 at 2:54 am
    Hello!
    Here’s a DVD architect question relating to file storage and back up.
    Once a dvd that is authored in Dvd architect, and the file is prepared, to save the job as back up on a disk can I simply save the prepared file folder or do I also need to save the mpeg file as well?
    I noticed that the prepared file folder is often almost the same file size as the mpeg itself so I figured it would be ok to delete the mpeg?
    Does anyone know if I wanted to load the file back in at a later date to make a copy – simply loading the prepared file then burning it in DVD architect would work?
    Or would you recommend to simply burn a disk then if required make a copy using copying software.
    This is still new to me so any help would be appreciated. Instead of deleting I’ve just been buying new hard drives – I’m up to 7 now. 😉
    Thanks – hope this makes sense.
    Cheers!
    Richard Klimesh replied 20 years, 9 months ago 3 Members · 5 Replies
  • Edward Troxel
    December 4, 2005 at 3:15 am
    If you simply want to make additional copies of the DVD at a later point, all you need is a copy of the DVD. Then you just need the VIDEO_TS and AUDIO_TS folders to burn additional copies.
    If you want to later reauthor the project, I would keep both the MPEG2 and DAR files.
    I suspect, based on what you wrote, you fall into the first category.
    Edward Troxel
    JETDV Scripts
  • Miss Moo
    December 4, 2005 at 3:25 am
    Thanks Edward – you’re always very helpful.
  • Richard Klimesh
    December 4, 2005 at 5:33 pm
    I’ve got a glitch in my brain, Edward. If you have a copy of the finished DVD from which to make copies, why would you also need the VIDEO_TS AND AUDIO_TS? Wouldn’t you need just one or the other?
  • Edward Troxel
    December 4, 2005 at 7:17 pm
    The DVD copy would have those two folders. You can just copy them back to your hard drive to make as many additional copies as needed. Technically, the AUDIO_TS folder will be empty but you’re more compatible if you include it.
    Edward Troxel
    JETDV Scripts
  • Richard Klimesh
    December 4, 2005 at 7:20 pm
    Ah. Thank you very much.
