DVD Architect anti-aliasing
Posted by Mark Altland on March 5, 2010 at 2:10 amI am having a problem of anti-aliasing on typed words on my menu. Is there anyway to correct the problem.
Mark
Mark Altland replied 16 years, 5 months ago 2 Members · 2 Replies -
Chris Young
March 7, 2010 at 11:38 amSuggestion. On each menu page look under the ‘General’ tab. The top entry in the list is headed ‘Reduce interlace flicker’ and make sure it is turned on for all menu pages. You may then find an improvement in the final render. I find that this varies considerably depending on the fonts used on the menus. Some work well some are nightmares when rendered.
Set up your menus and then use a sixty-second video clip and do a test render to check various font tests.Chris Young
CYV Productions
Sydney -
Mark Altland
March 9, 2010 at 4:05 pmI appreciate the help. I had the “reduce interlace flicker” turned on. I have made the text smaller and tried different text and it hasn’t help. I got curious & took the dvd to another TV and it looks perfect. Guess it is something with the tv/dvd player.
Thanks for you help.
Mark
