Activity Forums VEGAS Pro DVD Architect and Multiple Audio Tracks
  • DVD Architect and Multiple Audio Tracks
    Posted by David Crowe on September 27, 2009 at 12:11 pm
    I am trying to create a bluray disc which has multiple audio tracks. I set up 2 playlists which point to the same video files and setup the properties so that when you select playlist one it should play audio track 1 and when you select playlist two is should play audio track 2. It works fine in the preview but when played on a blueray player, it doesn’t work. It only plays audio track 1. Anyone else having this issue?
    David Crowe replied 10 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
