Activity Forums VEGAS Pro DVD Architect advice?
  • DVD Architect advice?
    Posted by Rick Dervisevic on March 17, 2007 at 6:02 pm
    Given that there is no forum for DVD Architect, I thought I would post here.
    I’ve recently edited a 3 hr project which I’m trying to get onto 2 DVDs. The project needed to be re-compressed before authoring and it seems in the process, I lost audio on the DVD and within Architect, audio waveforms are no longer visible and audio comes in choppy.
    This really sucks especially becasue the rendereing took so long… TWICE! Any advice or suggestions would be greatly appreciated.
    Brian Sinks replied 19 years, 6 months ago 6 Members · 8 Replies
  • 8 Replies
  • Gary Kleiner
    March 17, 2007 at 8:01 pm
    DVDA will marry your audio to your video if its in the same directory as the video and has exactly the same root name, for example xxyDr.mpg and xxyDr.ac3 . Otherwise, you can manually drop it in.
    The next question is why you are having a problem getting (presumaby) 1.5 hrs of video on the disc.
    Also, be sure you are not rendering your mpeg from the mpeg you made on the first try. Go back to the original project.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Rick Dervisevic
    March 17, 2007 at 10:26 pm
    Answer to your question as to why a 1.5 hr project wont fit on a DVD…
    The dispay I got from DVDA when I dropped the original project in was 4.9GB. Funny thing is when I look at the properties of the file it says its 2.3GB. Any idea why that would be?
    The original project was a combined audio/video MPEG when I dropped it in. I tried to drop them in as seperate files but they were out of sync, so I went back to my old method of an AUD/VID MPEG2. This was my first attempt at dropping them in as seperate files so maybe I did something wrong.
    I geuess I should have invested in your Authoring training series as well as the Editing series!
  • Don Bloom
    March 18, 2007 at 3:26 am
    As for using the numbers that DVDA gives you DO NOT! It lies!
    That’s harsh but it does give a gross over-exageration of the actual size of the project. Generally I take the file size from the file say 2.3gigs add in the AC3 audio say 138.5 mb and add ‘some’ in for menus. Real sophistcated I know but it works for me. Oh yeah if I have a music track under the menus I take the actual file size from that as well. A little addition and I come up with a fairly accurate number for the job.
    I’ve had DVDA tell me the project was up to 50% larger than what it really is.
    Don
  • Allen Zagel
    March 18, 2007 at 12:35 pm
    Same here. 1
  • Gary Kleiner
    March 18, 2007 at 3:17 pm
    [Allen Zagel] “Now I got to install my Vegas 7 / DVDA-4 for a wedding project and I’ll bet it’s doing the same thing. UGH!”
    Actually, the file size estimes are much better in DVDA 4.
    Gary Kleiner
  • Jim Prisby
    March 19, 2007 at 4:34 am
    Gary,
    Are you working on new training DVDs for Vegas 7 and DVDA 4? I am especially interested in DVDA 4. If so, do you have an ETA yet? I found your previous training DVDs to be very detailed and complete and yet easy to follow.
  • Gary Kleiner
    March 19, 2007 at 5:24 am
    Thanks for your nice comments.
    ETA on the next training DVDs is not firm, but I will keep everyone posted.
    Gary Kleiner
  • Brian Sinks
    March 19, 2007 at 7:07 pm
    I’ve found part of the difference is that before rendering the menus are usually using JPEG stills for the background that will originally make your project bigger than it will be. When preparing your DVD, DVDA will convert the JPEGs to smaller MPEG2 files. I have found dependent on how many pages of menus you have DVDA will estimate as much as 500mb over your MPEG2/ac3 media.
    You mentioned rendering out of Vegas as MPEG2 Audio/Video. As Gary said I would render the video as MPEG2 and the audio as ac3 with the same file name. I think DVDA will prepare the MPEG2 audio as ac3 anyway. Also, I believe the rendered file size of ac3 is smaller than a MPEG2 audio file.
