Activity Forums VEGAS Pro DVD Architect 6.0 not loading BluRay AVC file
  • DVD Architect 6.0 not loading BluRay AVC file
    Posted by John Frey on May 1, 2013 at 3:53 pm
    After switching back to Vegas 12 and DVDA 6.0 from Adobe Premiere and Encore, I used the Sony Blu-ray 1920 x 1080-60i 16 Mbps video stream setting to render an AVC file to burn to a BluRay disc. I decided to use this setting instead of the MainConcept BluRay setting. Once finally rendered, I am unable to open/play the AVC file with any program. I have read on previous threads similar problems for other users. Any solution or am I relegated to re-rendering the file with the MainConcept setting?
    John D. Frey
    25 Year owner/operator of two California-based production studios.
    Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
    Manish Ved replied 12 years, 8 months ago 3 Members · 2 Replies
  • John Rofrano
    May 4, 2013 at 11:37 am
    [John Frey] “I used the Sony Blu-ray 1920 x 1080-60i 16 Mbps video stream setting to render an AVC file to burn to a BluRay disc. I decided to use this setting instead of the MainConcept BluRay setting. Once finally rendered, I am unable to open/play the AVC file with any program.”
    I cannot recreate this problem. I just render a video as Sony AVC/MVC using the Blu-ray 1920×1080-60i, 16 Mbps video stream and I dropped the AVC file into DVD Architect Pro 6.0 without any problems. This seems to be something unique to your PC. Do you have any codec-paks installed that would interfere with reading AVC files? This works for me.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Manish Ved
    January 4, 2014 at 8:53 am
    I have the same issue. My video is around 2.5 hours long and was captured on a Sony TD20 camera. Vegas Pro 12 did not complain at all and rendered the AVC, MVC and AC3 files.
    Rendered using the Sony MVC 1280×720 60p codec
    I had installed VLC and GOM Player after installing DVD Architect Pro 6. I have since uninstalled both those programs.
    Surprisingly I found that if the rendered file was smaller (rendered only a small segment) it loaded perfectly in DVDA Pro 6.
    When I load a large (6GB) segment, the video is not displayed correctly in the DVDA 6.0 window (lots of green boxes)….any ideas?
