Activity Forums VEGAS Pro DVD Architect 5.0 & BLU-RAY
  • DVD Architect 5.0 & BLU-RAY
    Posted by Pete Locascio on September 18, 2008 at 9:10 pm
    I’m a little confused about DVD Architect and it’s BLU-RAY capabilities. After several attempts, I successfully rendered and burned a BLU-RAY project in Vegas PRO 8. Now, when I import that or
    an MPEG rendered project into Architect, does changing the properties to “BLU-RAY” instead of “DVD” actually produce a 1080i High definition disc if rendered and burned on a BLU-RAY disc in Architect 5.0? Also, on several occasions, when trying to import a project file, I’ve gotten a message that says the file is not in the correct format. I’ve tried changing the settings,but that doesn’t seem to solve the problem. Any suggestions? Thanks!!
    John Rofrano replied 17 years, 11 months ago 2 Members · 1 Reply
  • John Rofrano
    September 18, 2008 at 9:21 pm
    > Now, when I import that or an MPEG rendered project into Architect, does changing the properties to “BLU-RAY” instead of “DVD” actually produce a 1080i High definition disc if rendered and burned on a BLU-RAY disc in Architect 5.0?
    Yes. Usually I start a new project with the Blu-ray settings before I add any media, but changing it after you add the media will work as well. This is how I make both DVD and Blu-ray from the same DVD Architect project.
    What format did you use? From Vegas Pro 8.0 you should be using one of the MPEG-2 or AVC templates that start with “Blu-ray” in the name. Then render your audio as AC-3.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
