Activity › Forums › VEGAS Pro › DVD Architect 5 creates Audio_TS and Video TS — no lead in, disc is not playable
Posted by Walter Eldredge on August 4, 2015 at 9:20 pmI’ve created many DVDs with DVDArch 5.Ironically this one is a simple, one-video/one-menu button job. I have no idea why it is burning the component files and folders rather than creating a playable DVD. Presumably there is some setting I have changed without realizing it; if anybody knows what it is I would appreciate finding out.
John Rofrano replied 11 years ago 5 Members · 12 Replies -
John Rofrano
August 5, 2015 at 3:14 amI don’t know what’s causing your particular problem but when I run up against a problem like this I have DVD Architect create a DVD image (ISO file) and then I burn that with another program. In fact, I got into the habit of always making ISO files this way I can burn copies very easily with DVD Architect as customers need them.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Walter Eldredge
August 5, 2015 at 2:40 pmThat’s a really interesting idea – thanks, I will try it. LOL a new problem solving principle “If something won’t work, introduce a new step to make it more complicated.”
Gary Newlon
August 5, 2015 at 3:28 pmJohn is correct here. His solution has been part of my workflow for DVD burning forever. I burn a DVD master then use Roxio to burn an ISO image and just burn DVD’s using the ISO image. Never a problem. Just sayin’.
Walter Eldredge
August 5, 2015 at 8:50 pmThanks,guys. This works fine with Imgburn and the disc burn time is reduced.
Bob Peterson
August 5, 2015 at 11:28 pmActually, I almost always use this technique even though DVDA then burns the DVD. I always do the prep first, and then perform the burn after the prep. I’ve never had a problem with unusable disks.
Thayalan Paramasawam
August 6, 2015 at 1:29 amGood Morning Sir (Mr.John Rofrano),
As you say (I run up against a problem like this I have DVD Architect create a DVD image (ISO file) and then I burn that with another program)….how to change DVD file to DVD image (ISO file) and whats is another program?At the moment i use burn aware as you recommended to me 3 years ago.
I am really having probleum,my customers always complaining me that the DVD always freeze and play.DVD Writer : Plextor
DVD MEDIA : Verbatim
DVD Architect PRO 6
Thirt Part Program : Burn AwarePls help on this matter.
Thank You
Thayalan Paramasawamhttp://www.jptsskyvision.com
System Details:
Motherboard – Asus M5A99X-EVO,HardDrive1 boot C:SSD Kingston,Processor – Amd FX 8350 4.0/4.2 GHZ,Ram – 16 GB,Graphic Card – Asus Gtx 650 1GB DDR 5,Blu Ray Writer – Plextor PX-B950SA,Operating System – Window 7 Pro 64 Bit and Editing Programe – Sony Vegas Pro 12 -
John Rofrano
August 6, 2015 at 12:34 pm[Thayalan Paramasawam] “I am really having probleum,my customers always complaining me that the DVD always freeze and play.”
There are usually 3 causes for this:
- The video uses too high a bit rate
- The media is low quality
- The burn was too fast and you need to use a slower speed
So I have to ask:
- What bit ate are you creating the video at on DVD?
- What exact Verbatim disc are you using? because they have a “value line” that is cheap and should not be used and they also have a more expensive line of discs
- How fast are you burning?
I still recommend Burn Aware because it’s easier to use than ImgBurn but that’s an alternate program you can use. I must confess that since I’ve moved to the Mac, I don’t burn discs with Windows anymore so I haven’t used Burn Aware in over a year. I assume it’s still good.
~jr
August 6, 2015 at 3:45 pmThank You Sir (Mr.John Rofrano) reply my question.
If my video below 1 hour,i use CBR 8,000,000 and more than 1 hour i use VBR.What exact Verbatim disc are you using? because they have a “value line” that is cheap and should not be used and they also have a more expensive line of discs?
I need to check back because the lable is missing but i just both in malaysia RM 50.00 = USD 12.7808.What means exact and value line?Is spec for DVD.How fast are you burning?
I always use the lowest speed 6x,my dvd/Blu Ray writer plextor.Its goes until 6x only.Thank You
System Details:
John Rofrano
August 7, 2015 at 5:25 pm[Thayalan Paramasawam] “I need to check back because the lable is missing but i just both in malaysia RM 50.00 = USD 12.7808.What means exact and value line?Is spec for DVD.”
Verbatim has two series of discs. The DataLifePlus discs are the ones you want. The Value Series or as they are now called, DVD R Life Series are inexpensive discs that are meant for non-critical applications. I would not use these for clients or any storage that you plan to keep for a long time. If you are going to buy Verbatim DVD’s, only get the DataLifePlus discs.
This is critical for everyone to understand. Using a brand name is not enough. Every brand has a “value” line which are cheap and should not be used for critical work. Some brands like Memorex are just all cheap and should be avoided all together. Some brands like Fuji you need to look at which country they are created (Taiwan or China) in because one country produces junk while another produces good discs. I keep forgetting which is which so I just avoid Fuji now. It’s something to really be careful about.
~jr
