Activity › Forums › VEGAS Pro › DVD Architect 3.0 VIDEO_TS
  • DVD Architect 3.0 VIDEO_TS
    Posted by Justin L. on September 26, 2010 at 4:09 pm
    Hey guys!
    I’m having trouble burning a Dual Layer DVD at DVD Architect.
    I then found one forum suggesting to use a program called “ImgBurn”. The only problem is, I can’t locate the VIDEO_TS. Any suggestion on where can I find it?
    Stephen Mann replied 16 years ago 2 Members · 1 Reply
  • Stephen Mann
    September 26, 2010 at 5:22 pm
    You don’t provide enough clues about your workflow, but the video_ts and audio_ts folders (both are required even though audio_ts is always empty) are created by the program that “prepares” your DVD files.
    My workflow is to make he mpeg/ac3 files in Vegas, then move them into DVDA to author the DVD menus. When I select “Prepare” in DVDA, the program makes the _ts folders. I use DVDA to burn the discs, but you can use any DVD burning software at this point.
    In DVDA you are prompted to provide a path to your DVD files. This is where DVDA puts the _ts folders.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
