Activity Forums VEGAS Pro DVD Architect 2 PROBLEMS
  • DVD Architect 2 PROBLEMS
    Posted by Matt Schwartz on February 5, 2008 at 1:06 am
    PROBLEM 1. Hi this has always worked for me but now it’s a problem for some reason, I have 10 chapters in scene selection and I set the “destination” after each scene back to scene selection, but it’s NOT WORKING! When I preview, the scene does not end and return it plays past its endpoint, what else should I be setting? Cannot figure out what is wrong. Somewhat URGENT, have a deadline on this, thanks. The last scene DOES return to scene selection! But only the last.
    PROBLEM 2: I want to add a separate menu item, so that when you click on it, it goes to ONE PARTICULAR SCENE. I cannot figure out how to do this, I tried adding a submenu, it doesn’t seem to allow you to go directly to one scene. There must be a way, how do I do it.
    Edward Troxel replied 18 years, 7 months ago 2 Members · 3 Replies
  • Edward Troxel
    February 5, 2008 at 3:28 am
    If you want all 10 chapters to return back to the menu individually, you’ll need to add that media to the project 10 times and modify the out-point for each chapter point appropriatedly.
    If you want each piece to return to the menu (especially if you don’t want a “Play All” option), it’s easier to just render each piece separately.
    Edward Troxel
    JETDV Scripts
  • Matt Schwartz
    February 5, 2008 at 8:28 am
    Yes and now that I think about that, why would I want each scene to return separately. The scene selection applet works fine, it just continues with the whole movie at a particular scene, this is just fine, HOWEVER, How can I have a menu item for ONE SCENE say a TRAILER or should I render this separately, probably so.
  • Edward Troxel
    February 5, 2008 at 7:39 pm
    Yes, just render that separately.
    Edward Troxel
    JETDV Scripts
