Activity › Forums › VEGAS Pro › DVD Architect 2 – movie links are not rendering
  • DVD Architect 2 – movie links are not rendering
    Posted by David Dickerson on March 30, 2007 at 4:46 pm
    I created a DVD that uses 6 different movie files (separated into .ac3 and DVDA compatable mpg2 files each). I used a text-only link option, and a mask overlay the first time, and a rectangle overlay the second time. There is a movie file as a background media (again, .ac3 & mpg). Every time I render the DVD out, the links do not show up on the menu. The overlay does, but not the individual links. You can still navigate the menu and activate each movie.
    Anybody have any idea what would cause this problem?
    Thanks.
    Edward Troxel replied 19 years, 6 months ago 2 Members · 2 Replies
  • David Dickerson
    March 30, 2007 at 9:22 pm
    Apparently it is the movie background that is causing this problem. I opened up DVD Architect 1 and was able to render out a perfectly fine DVD. Is this a bug in DVDA2?
  • Edward Troxel
    March 31, 2007 at 2:14 am
    Are you using the most current version of DVD A 2? I know there was a release at one point that had an issue similar to what you are describing.
    Edward Troxel
    JETDV Scripts
