Activity Forums VEGAS Pro dvd architect
  • dvd architect
    Posted by Linda Adams on August 5, 2008 at 5:50 pm
    I’m using vegas 8.0 pro when veiwing rendered video it lookes great. But when I move it into dvd architect and render it,it has a major flicker. My video is about 70 min and maybe 1/3 of it is flickering. When rendering in vegas i used windows media. Architect i used the default settings. It flickers with both still shot and video. could you help me with this.
    Linda
    Terry Esslinger replied 18 years, 1 month ago 3 Members · 4 Replies
  • Terry Esslinger
    August 5, 2008 at 10:30 pm
    If you are going to a dvd with this why did you render it as WMP in Vegas? DVD is MPEG2 -always-. Your best flow is to render in Vegas as Mainconcept DVDA MPEG2 with no audio. Then render again the audio only as AC3. Then drag those files into DVDA. At 70 min DVDA will probably not have to rerender. I think that your quality issue stems from too much rendering!
  • Douglas Spotted eagle
    August 5, 2008 at 10:36 pm
    The FREE DVD Prep tool from VASST will set the correct rendering parameters from within Vegas *every* time, and includes the AC3 file to the same folder, so…it becomes a one-button render, with everything correctly placed.
    https://www.vasst.com/product.aspx?id=30de2ba2-0bca-4a0b-9564-951b88a127b1
    Douglas Spotted Eagle
    VASST
    Certified Sony Vegas Trainer
    Aerial Camera/Instructor
  • Linda Adams
    August 6, 2008 at 8:08 pm
    How do i keep it from rendering again in DVDA. When I hit Make burn a DVD it renders it.
  • Terry Esslinger
    August 7, 2008 at 4:10 pm
    If you render in Vegas to Main Concept DVDA compliant MPEG2 video stream and audio to AC3 then DVDA should not have to rerender it. For a 70 min video you should be able to use 8,000 000 CBR setting but its always good to check with a bit rate calculator when you start to get over an hour.
    DVDA will rerender if your video is too long to fit, or if it isn’t DVDA compliant. This is the way to keep the best quality.
