Activity Forums VEGAS Pro DVD arch themes
  • DVD arch themes
    Posted by Enrique Orozco on November 20, 2008 at 4:23 pm
    I’m trying to “import” to another machine some themes that I designed from menus on DVD arch … I can’t find the theme files that I created and that appears every time I turn on DVD arch (on 1st. machine)… I find the folder where every other themes are but not the ones I created… any help would be greatly apreciated….
    kind regards
    Enrique Orozco
    Bernard Dallaire replied 17 years, 9 months ago 3 Members · 3 Replies
  • Steven Quan
    November 21, 2008 at 7:28 pm
    When you click on “Save” or “Save As” does it show the folder where the file is being saved?
  • Enrique Orozco
    November 21, 2008 at 7:38 pm
    … nop.. it is automatically created (appearing on your themes graphical menu)…
    thanks
    Enrique Orozco
  • Bernard Dallaire
    December 13, 2008 at 1:40 am
    Hi Enrique,
    When you export the menu as a Theme, DVD Architect creates a directory using the name of the theme, so for instance if you name your team MYTHEME, the directory will be called MYTHEME.THM, that directory is created under “C:\Documents and Settings\\Application Data\Sony\DVD Architect Pro\4.5\Themes”.
    Please here I used my setup which uses Architect 4.5, I will assume 5.0 the directory up from Themes would be 5.0.
    You can “probably” copy that directory (MYTHEME.THM) in the same location on your other computer and expect to see it in DVD Architect theme collection.
    Bernard
    Have an ice day 😉
    Bernard
