Activity Forums VEGAS Pro DVD Arch. menu text highlighting
  • DVD Arch. menu text highlighting
    Posted by Dave James on April 7, 2011 at 3:56 am
    This is the same issue I posted earlier – but I changed the subject and explanation – hoping to get this figured out.
    Searching the internet seems to indicate that known – and essential unsolvable issue is that of the highlighting of DVD menus will not anti-alias correctly, allowing some of the underlying color to show through – when for example you have blue text and red highlighting – it looks extremely bad. I have done all sorts of combinations of colors and transparency in the masking – but can’t get it cleaned up.
    Are there any tricks to accomplish this?
    Dave James replied 15 years, 5 months ago 3 Members · 9 Replies
  • 9 Replies
  • Stephen Mann
    April 7, 2011 at 2:45 pm
    It might help if we could see a screen shot of your problem. Also, just what style of DVD menu are you trying to achieve?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Dave James
    April 7, 2011 at 3:40 pm
    Thanks. I’ve attached a screen shot of the highlight menu. You can see what I’m trying to do. I’ve been able to reduce the problem from the default settings of blended colors by adjusting the specific color itself and transparency for the outline and anti-alias colors. I guess the real issue is that the underlying menu item isn’t hidden – but even if you change the background color to white in the highlight – it still doesn’t have good anti-aliasing itself – completely unlike the anti-aliasing used for the text of menu item.
  • Stephen Mann
    April 7, 2011 at 5:28 pm
    I don’t think you can attach an image to this forum. You need to post it somewhere else and put the link here.
    Steve Mann
    http://www.mmdv.com
  • Dave James
    April 7, 2011 at 5:46 pm
    When I saw the upload icon – and it worked, I just assumed that, well, it worked. Here’s a link:
    https://www.4shared.com/photo/w7lfwVyT/DVD_menu_-_revised.html
  • Mike Kujbida
    April 7, 2011 at 6:50 pm
  • Stephen Mann
    April 7, 2011 at 6:54 pm
    It’s never worked for me. What’s the secret?
    Steve Mann
    http://www.mmdv.com
  • Mike Kujbida
    April 7, 2011 at 7:00 pm
    Steve, if you mean uploading images, here are the steps I use.
    1. Click the icon.
    2. Browse to the image and click “Open”.
    3. Click “upload image”.
    4. Click the image name in the top right corner.
    5. Click and copy the information in the “Embed” box on the left.
    6. Click the “x” next to the image name (I’m not sure this step is necessary but I do it anyway).
    7. Close the window.
    8. Paste the link into your message.
    9. Post the image.
  • Stephen Mann
    April 7, 2011 at 7:03 pm
    I never use the anti-alias color in the color sets. As you have discovered, the resolution is too low to get good results.
    Here’s how I would do this:
    In Photoshop, you will create two files. One is the menu image with strategically located menu labels. Highlight them, shadow them, make them glow, whatever…. The second file is your button mask. This will be the pointer that you move from menu label to label. (You can have as many masks as you have labels, or they can all be the same). The size is irrelevant since DVDA will scale the image to match the image frame. (This will be clear later).
    Making the mask:
    B&W Image, save as PNG file. The black areas of the mask will be the color in Color Set 2.
    In DVDA, insert a new menu, or select the top menu.
    Replace the background media with your menu image that you created in Photoshop.
    Insert your media or sub-menu in this menu. You will now have one or more buttons on your menu each pointing to a media, sub-menu or navigation.
    Select the Menu Page Properties.
    General Tab:
    Selected Buttons: Color Set 1
    Activated Buttons: Color Set 2
    Inactive Buttons: Transparent or Color Set 3
    One at a time, double-click on the button to select that item.
    In the Properties Window:
    Media
    Button Style:
    Image Only
    No Thumbnail
    No Mask
    No Frame Media
    No Frame Mask
    Highlight:
    Style: Custom
    Mask: Replace with the mask you created in Photoshop.
    Mask Mapping: Transparency
    Hint:
    You can right-click on a “finished” button and copy button attributes, then right-click on another button to paste the attributes.
    Using this process, I can pretty much replicate most Hollywood-style DVD menus.
    Steve Mann
    Steve Mann
    http://www.mmdv.com
  • Dave James
    April 7, 2011 at 8:07 pm
    Great. Very clear. Thanks so much.
