Activity › Forums › VEGAS Pro › dvd arch menu showing red squares
  • dvd arch menu showing red squares
    Posted by Linda O’connell on August 30, 2010 at 9:56 pm
    I have 7 buttons on a scene selection menu.
    One of the buttons, when you click on it (before preview) shows it overlapping with a red highlight box going into three other menu buttons. When I preview that red “box” is white.
    I have tried changing the size (but all the buttons are the same size) I have tried changing the highlight to underline.
    But it still is showing up
    Any ideas?
    Fred Robinson replied 16 years, 1 month ago 2 Members · 2 Replies
  • Linda O’connell
    August 30, 2010 at 10:55 pm
    Everytime I post on here, I find out my answer about 2 minutes later..even if I spend an hour looking.
    I discovered that I had switched up a 2 title boxes. So the image and the title names weren’t with each other as then should have been.
  • Fred Robinson
    August 31, 2010 at 7:36 am
    Heh heh. That posting-on-here-then-find-the-answer-straight-after trick often works for me too.
