DVD Arch Backgrounds
Posted by Linda O’connell on November 12, 2009 at 4:57 pmI want to use a background on DVD Arch and print it on my DVD label. Is there somewhere, where those backgrounds/pictures are so I can do that? I can’t seem to locate them.
Tom Smith replied 12 years, 5 months ago 5 Members · 6 Replies -
Mike Kujbida
November 12, 2009 at 5:00 pmSee my replies in the Architect theme into sony vegas thread.
Linda O’connell
November 12, 2009 at 5:05 pmThanks. I tried to search for this answer but apparently using the wrong terms!
Pete Locascio
November 12, 2009 at 9:49 pmThis worked for me;
1) open the desired background on the DVDA menu page.
2) Get rid of the “Menu1” graphic that is on the page.
3) right click the page and select “explore containing folder”
4) find the background in the window that opens up,right click it and select “copy”
5) then paste it into documents or whatever place you want.
6) you can then open your Vegas project and import the file.
Hope it works for you.I use Vegas Pro 9c and DVDA5
Pete Locascio
November 12, 2009 at 9:59 pmI forgot to add that you should also be able to import it into your DVD labeling software too. I use Media Face and can import my own pictures from my files.
August Taconi
November 13, 2009 at 3:04 amAnother option to using Arch backgrounds is to set up DVDA graphic editor preference under OPTIONS – PREFERENCE – VIDEO. Set your preferred graphic editor. I use Corel Paint Shop Pro. Now when you select a background in DVDA, just right click on the image and select open in graphic editor. You can now edit and save the image anyway you like. It’s quick and easy.
Good luck
Tom Smith
April 7, 2014 at 4:07 pmI can recommend you a wonderful program with which you can make labels for discs. You can download cd cover designer from the official site (link). And learn from video tutorials
