Activity Forums VEGAS Pro DVD Arch. 2 question
  • DVD Arch. 2 question
    Posted by Angelo Caruso on May 22, 2005 at 2:46 pm
    Hello to all,
    Here is the situation. On the main title screen of my DVD I have 2 buttons. (Play & Scene Selection.) I place a 30 second mpg. in the audio/video properties for background motion menu effect. I preview the project on the computer and the words “Play & Scene Selection” are there. Now, I render and burn the project and the words are gone, but the highlight areas are still visible. What I am I forgetting to do to the words before rendering? Thank you in advance for all of your help.
    Sincerely,
    Angelo Caruso
    Angelo Caruso replied 21 years, 4 months ago 3 Members · 4 Replies
  • Gary Kleiner
    May 22, 2005 at 3:42 pm
    Are you running 2.0b?
    Gary Kleiner
    Vegas Training and Tools.com
  • Angelo Caruso
    May 23, 2005 at 4:59 am
    Hello,
    Thank you for your response. I am running 2.0 I am going to try to update.
  • Brett Jones
    May 24, 2005 at 5:01 pm
    I had this same problem with disappearing menu text.
    Bottom line, I applied a different theme to the menu page by dragging and dropping a theme selection from the Themes tab to the Menu window. I then reconstructed the menu. The menu text did show up upon burning to disk after that.
    Things I tried to adjust that did not fix the problem are as follows:
    1) Individually deleting and reinserting every menu item, like backgrounds and labels.
    2) Changing selection highlight masks.
    3) ‘Bringing to Front’ of selection buttons.
    4) Changing fonts/sizes on the buttons.
    5) Making sure highlight masks were not overlapping.
    The preview in DVDA functioned perfectly. It was only after rendering/burning this error showed up. A frustrating aspect was that only the main menu was acting this way. I could navigate the main menu and the highlight mask would show up where the labels were, but the words would not show. Other than that, the DVD worked fine.
  • Angelo Caruso
    May 24, 2005 at 6:20 pm
    Hello,
    Mr. Kleiner hit the nail right on the head. After upgrading to 2.0b, I have not have the same problem. Thank you again for all of your support.
    Sincerely,
    Angelo Caruso
