Activity Forums Avid Media Composer DVD and Quicktime
  • DVD and Quicktime
    Posted by Sean Mcculley on December 22, 2005 at 7:12 pm
    I’m trying to create a DVD disc that contains both DVD-video and a Quicktime (DVD-ROM). I am creating my DVD through Avid DVD by Sonic. The DVD-Video portion seems fine. My problem is with the Quicktime. When I try and open it, Quicktime says that it doesn’t have a valid extention and will not play correctly.
    Any info would be great!
    Sean
    Avid Adrenaline
    For those with the Avid DVD by Sonic Manual – I followed the instructions on page 142 to add the ROM data to the DVD if this makes any difference.
    Sean Mcculley replied 20 years, 8 months ago 3 Members · 3 Replies
  • Michael Phillips
    December 23, 2005 at 12:42 am
    Does the QuickTime movie have a .mov extension?
  • Jon Zanone
    December 23, 2005 at 2:21 pm
    Are you testing this on the same machine your Avid is installed?
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Sean Mcculley
    December 23, 2005 at 3:08 pm
    I’m checking the quicktime on another machine. It does have the .mov extention on the end. I might have a clue as to what is happening – I upgraded quicktime when I upgraded the Adrenaline and haven’t on the other computers and I am also making a 720×480 movie which might be causing irregular playback. I’ll do more testing to see if I still get the “wrong extention” error.
