Activity › Forums › Adobe Encore DVD › DVD after burning got very blury
  • DVD after burning got very blury
    Posted by Bilaocabecao on November 9, 2007 at 5:26 pm
    Hello All,
    After burning a final DVD disc I noticed it got very blury…any sugestions about exporting to a DVD Disc?
    Am I doing something wrong over the compression settings…I haven’t change anything in there..I’ve used the standard settings..Thank you
    Cabecao
    Jeff Bellune replied 18 years, 10 months ago 2 Members · 4 Replies
  • Jeff Bellune
    November 9, 2007 at 6:49 pm
    What version of Encore?
    What operating system?
    What export settings from what editing program were used?
    What file format is the file that was imported into Encore?
    What codec is used in the file that was imported into Encore?
    How long (in minutes) is the video content that will be used in the DVD?
    What are your Encore project settings (DVD, Blu-ray?)
    What are your Encore transcode settings?
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
  • Bilaocabecao
    November 9, 2007 at 7:45 pm
    CS3
    PC 4 quad – 8GRAM – XP professional
    all the footage came from After Effects CS3 | quicktime file | high quality
    .mov ( none compression )
    none
    4 clips each one with 6 minutes long
    The footage has an HDV format ( 1440x1080i ) In Encore I’m using Blue-Ray, but when I output to a DVD disc I use DVD settings and not Blue Ray
    Automatic | H.264
    I’m testing now changing the transcode settigns to Custom and selecting the Mazimum quality ( 1440×1080 ) option.
  • Bilaocabecao
    November 9, 2007 at 7:48 pm
    One more thing I would like to add:
    Even in my previews after Rendering the quality is bad (blurry)…Don’t know if that matters
    Thank you again !
    CAbecao
  • Jeff Bellune
    November 9, 2007 at 8:53 pm
    I don’t know if the answer is this simple, but a Hi Def source will visibly lose resolution and have degraded video quality when re-sized for Standard Def DVD.
    Blu-ray at 1440×1080 has more than four times the resolution of SD DVD at 720×480.
    Can this resolution difference account for the “blurriness” that you are seeing?
    -Jeff
