Activity Forums VEGAS Pro DVD A Button question
  • DVD A Button question
    Posted by Klaus Boehmer on September 4, 2010 at 2:19 pm
    hi there
    I’ve started buying sony vegas and DVD A about six years ago and ever since have not only been a vivid user but also an active member of the German sony vegas support forum. however, there is one thing with the DVD A that I never figured out: is it possible to use your own multi color buttons for any given menu, with the selected button visible (and keeping all its colors!) while the unselected buttons are invisible? here’s an example of my current project, how I would like to have it
    https://img820.imageshack.us/img820/6079/bild01p.jpg
    https://img72.imageshack.us/img72/7128/bild02n.jpg
    as you can see, my “button” jumps with its selection from left to right
    over the years I’ve discovered two ways to accomplish this result: either you put the “buttons” on a monochromatic background as part of the background video and then use masks with the same background colour in DVD A to hide them when not selected – or you effectively create (in my case) three different sub menus, that means when you choose the “down” button on your remote control you do not stay in the same menu but are transferred to another (sub) menu
    both methods have its restrictions: number one only works well with a monochromatic and static background, number two results in the reknown “hick up” while jumping between the sub menus
    now I wonder: is there really no third way, without these restrictions? and if not, is this simply a DVD A or a general authoring software restriction?
    thanks for your support and please, excuse my English, I’m not a native speaker 😉
    Klaus Boehmer replied 15 years, 11 months ago 2 Members · 2 Replies
  • John Rofrano
    September 4, 2010 at 2:48 pm
    This is a restriction in the DVD spec and has nothing to do with the authoring software. A DVD player can only highlight an area with a color. That’s it. If you look at fancy Hollywood videos, they choose their colors carefully to make the highlighting look as natural as possible but in the end, they are just highlighting an area of the screen with a color to make the button look like it’s changing.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Klaus Boehmer
    September 4, 2010 at 2:59 pm
    too bad but thanks for the quick answer
