Activity › Forums › Adobe Encore DVD › DVD 9 Region code error
  • DVD 9 Region code error
    Posted by Nitin Kulkarni on September 6, 2010 at 2:45 pm
    hi,
    I use encore 2.0 for authoring i want to send master in region 5 code.
    1. I write image file from encore on hardisk
    2. Then i Open image file in “Gear pro mastering” Software for DDP image
    3. I create DDP image in “Gear PRO” Layer 0 & layer 1 and i write in two dvd5 as data DVD
    when i send for replication there error shows ” Control data & main
    data region code disagree” & ” Layer Break on celll Boundry”
    please anybody help
    Daniel Ludwig replied 16 years ago 2 Members · 3 Replies
  • Daniel Ludwig
    September 7, 2010 at 5:02 am
    hi nitin,
    have you set any region-codes on your gear-master-DDP-master?
    if you´ve created an ISO-disc-image the region-code is region-free by spec, and if you created a specific region-code for the master, they will be different – this is a violation against the DVD-specs.
    so the better choice will be to create a DVD-disc-folder instead of creating an ISO and to create the DDP-image from the folder.
    cheers
    danny
  • Nitin Kulkarni
    September 7, 2010 at 6:05 am
    hi Daniel
    thanxs for your reply.
    In encore 2.0 I have set region code 5 and created a video folders. after that in gear pro I open that dvd folder and write DDP image. Is there any particular setting in gear pro for setting a region code or it should be without any setting?
    Regards
    nitin
  • Daniel Ludwig
    September 12, 2010 at 8:01 pm
    nitin,
    I don´t know if gearmaster will change any informations from your previous selected region 5, but if not you need to set the same region-code for your DDP, otherwise they will be different and the replication will be refused again, because the header of your DVD will missmatch.
    cheers
    danny
