Activity Forums Adobe After Effects DVD 4.3 and 16.9
  • DVD 4.3 and 16.9
    Posted by Dane Sparkey on October 12, 2008 at 7:40 pm
    Hi, does anyone know if i can set a comp in after effects to a to produce a video that can viewed on both pal 4.3 and 16.9 screens and always maintain a cinema style letterbox effects.
    I would like to keep the letterbox effect as i would like subs in this area, also all of the original material has been produced in comps at 1024*576 square pixel, the master comps hold material of mixed content such as 3D rendered stills, real video, stills and after effects fx and text..
    Does anyone know a good work flow from material produced at 1024*576 square pixel to 16.9 DVD played aimed for both 4.3 and 16.9 monitors and maintain a letterbox that can hold subtitles?
    thanks for your replies…
    Dane Sparkey replied 17 years, 11 months ago 2 Members · 4 Replies
  • Roland R. kahlenberg
    October 13, 2008 at 10:35 am
    You’ll need to put both versions onto the DVD and have a menu where either version can be selected by the viewer.
    1024×576 is PAL 16:9. So you’ll have to nest that and then letterbox it to suit your needs.
    For the 4:3 letterboxed version, just nest the 16:9 comp into a normal 4:3 comp and scale width and height by 75% to get a letterboxed version.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Dane Sparkey
    October 13, 2008 at 11:02 am
    Thank you for the reply,
    Yes, i was working along those lines you suggested. Problem i have found is the nesting* with the 1024*576 if i make a comp in AE pal dvd size and next my comp into it the image is pixelated, i have been using 1024*576 square pixel for all of my AE comps. If i export from AE direct from this comp size and import to encore it reads it as 16.9 and all looks fine but i wont be able to add text in the letterbox area…
    no solution for this i think… do you?
    October 13, 2008 at 2:36 pm
    I believe that you have used the term pixelation incorrectly. Pixelation is used to describe that artefact that results from scaling up a raster image beyond its original size resulting in enlarged pixels.
    Therefore, if you nest your 1024×576 comp into a 720×576 comp, you shouldn’t see any pixelation. What I am assuming that you see is in fact a squashed image due to you resizing the 1024×576 nested comp to fit into the 720×576 comp. If you did this, then you are wrong.
    WHen you nest the 1024×576 comp into the 720×576 comp, you shouldn’t resize anything. The end result is that you will lose the edges of your 1024×576 comp. Perform a Google using the keywords, pan-scan & DVD to get a better idea on pan and scan techniques.
    HTH
    RoRK
  • Dane Sparkey
    October 14, 2008 at 10:08 am
    Yes I realized this and managed to work out a solution.
    Many thanks for your help.
    dean
    I like my mouse cold on a morning…
