Activity › Forums › Apple Final Cut Pro Legacy › DVCProHD to HDV
DVCProHD to HDV
Posted by Rich Rubasch on June 13, 2008 at 4:30 pmI have a Panasonic 1200a deck (no Firewire option) a Sony M25u HDV deck and a Kona 3 with breakout…intel quad core.
I have 2 DVCProHD tapes that I need to get onto an HDV tape…timecode does not have to match.
Do I digitize the DVCProHD to HDV and output via firewire to the HDV deck?
The editor has all HDV tapes and is in the middle of the edit, and has requested these DVCProHD tapes to go to HDV tapes.
Rich Rubasch
Tilt MediaAndrew Kimery replied 18 years, 3 months ago 5 Members · 9 Replies -
David Roth weiss
June 13, 2008 at 4:48 pmRich,
I’ll bet no one knows the answer to this one, primarily because the editor you’re doing this for has come up with a completely hair-brained idea that no one has ever done before, because its such a bad idea.
Taking a highly compressed HD source and compressing it again when it gets laid down on HDV tape, which will happen, is not gonna be good. They would do far better to have you simply digitize it to whatever format they need via your Kona card and deliver the QT files to them on a firewire drive. Or, are they working on Premiere of something that?
David
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Arnie Schlissel
June 13, 2008 at 5:07 pmI’m not familiar with the Sony deck. If it has SDI, the simplest thing is to just connect the two decks that way & make a direct dub. I don’t think you’ll see any better quality by any other method.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Rich Rubasch
June 13, 2008 at 6:48 pmI don’t know of any HDV deck that has HD SDI in. Only HDMI out and we use the convergent to convert that to HD SDI.
But I need to output HDV to the deck from FCP.
I don’t have the firewire option on the DVCProHD deck. Panasonic assured me that they don’t have a firewire option board laying around.
Rich Rubasch
Tilt Media -
Rich Rubasch
June 14, 2008 at 2:28 amIf you’re keeping score, David suggested that it might not even be possible, nor would I want to.
Here’s why he’s wrong.
An editor owns a Sony HDV camcorder. Shoots and edits in HDV…hey it’s his camera, his choice. he has a friend in another city who has a DVCProHD camera. He is available to shoot a once in a lifetime event, so the guy hires him. He approaches me to see if I can dub the DVCProHD to HDV tape.
I bite.
Here;s what I did.
Digitize two 30 minute DVCProHD tapes via 1200A deck and Kona 3 to 1080 60i DVCProHD.
Export Ref clips of the two tapes and import into compressor. Apply the HDV 1080i 60i preset and cook them. Each clip takes a little under an hour to transcode. (Quad Core Intel – 3.0 ghz)
Import those into FCP and set up an easy setup for HDV 1080i 60i. Hook the firewire from the MacPro to a Sony M25U deck.
Hit print to tape. Wait about 5 minutes while FCP analyzes the HDV stream to make sure it checks out…Print to tape begins.
Actually the transcoded HDV clips hold up very well to the source footage. No apparent gamma shifting and other than MPEG compression blocks, looks very good.
So, 30 minutes to upload each tape, 1 hour to transcode each clip and 30 minutes back out to tape. A straight dub would have taken 30 minutes per tape anyway, so if I figure about 4 times the running time of the footage I should be pretty close to calculating how much time it will take the next time.
And I’ll bet there will be a next time.
So there, David!
Rich Rubasch
Tilt Media -
Andrew Kimery
June 14, 2008 at 4:38 amJust for future reference the Sony HVR-1500 has HDSDI in and out.
-A
David Roth weiss
June 14, 2008 at 5:27 amRich,
I’m very happy that you and your client are both happy. Rather than being concerned with keeping scores such, let me tell you why I poo-pooed the idea.
First, DVCProHd as recorded to P2 from HVX200 cameras is, at least to my eye, soft right out the box. Then there’s the compression that happens everytime a signal goes to HDV tape. Then there’s the compression that happens when uncorking that bottle and redigitizing again back to QT. Etc, etc, etc…
So, I never doubted you or your ability to do the job, I doubted the wisdom of doing the job for the aforesaid reasons of quality. That being said, if no one can discern the difference, then perhaps that tree never fell in that forest after all.
Meanwhile, have a good weekend.
David
David Roth Weiss
Director/Editor
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY â„¢
Ken Jones
June 14, 2008 at 2:06 pmI own an HVR-1500 with all of the optional input/output cards.
This deck will output HD-SDI and SD-SDI, but will only input SD-SDI. -
Rich Rubasch
June 14, 2008 at 4:37 pmThanks Ken….this sort of confirms that HDV really only wants to travel over a firewire cable. Not too surprising, and in fact, Sony has probably repackaged the DSR 1500 DVCAM deck to allow it to playback HDV thru an HDSDI output, but is basically the same recorder.
I assume native RS422 control as well, component inputs and XLR?
Woe is the HDV format!
Rich Rubasch
Tilt Media -
Andrew Kimery
June 15, 2008 at 2:12 am[Ken Jones] “I own an HVR-1500 with all of the optional input/output cards.
This deck will output HD-SDI and SD-SDI, but will only input SD-SDI.”Ah, thanks for the correction Ken.
-A
