Activity › Forums › Apple Final Cut Pro Legacy › DVCPROHD to digibeta
Posted by Dan Archer on April 1, 2008 at 8:58 pmHello Cows, I have a project at dvcprohd 720p60. Iam trying to output to a Digibeta and keep getting an error that says “You may have attempted to output a clip with compression settings that do not match the current output settings. Try nesting the clip in a sequence with the correct settings.” I have even made a sequence that is 525 and all that and still get the same error. Can anyone help. Thanks in advance.
A cut is a cut & a dissolve is a disolve, and not just anybody with a system is a pro.
Larry Asbell replied 18 years, 6 months ago 5 Members · 8 Replies -
Mark Maness
April 1, 2008 at 9:06 pmWhat is your output/capture card?
If you have an AJA or a Blackmagic card you need to let the card do this for you.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
Dan Archer
April 1, 2008 at 9:28 pmI am on an AJA Kona3. I am trying to let it do the downconvert. But it seems that my FCP dosent like something and I cant figure out what….
Mark Maness
April 1, 2008 at 9:52 pmAs long as you properly setup the Kona 3 output, you can go just about anywhere with it.
What version of the Kona 3 software do you have? Do you have the latest?
Wayne Carey
Schazam Productions
Jeremy Garchow
April 1, 2008 at 9:52 pmALright. to do a down convert with a Kona you leave your FCP in an HD easy setup. So in your case, choose your AJA Kona3 720p easy setup.
Then go to the Kona Control Panel. On the output triangle (SDI 1 or SDI 2 or analog, whatever) right click on it and choose secondary from the drop down list. Then right click on it again and choose 525i. You should see a little down-convert icon popup and your digibeta should be happy.
Jeremy
Warren Eig
April 1, 2008 at 11:45 pmAre you trying to insert editing using the insert edit button in the master to tape window? if so that is the bug. Drag the sequence to the insert edit window instead.
Warren
Warren Eig
O 310-470-0905email: warren@babyboompictures.com
website: https://www.babyboompictures.comhttps://www.atomfilms.com/af/content/knitwits
https://www.atomfilms.com/film/family_xmas.jsp -
Dan Archer
April 2, 2008 at 12:08 amHow you new that I will NEVER know. That was It!!! I thought i was going crazy. Is that a standard bug or something unique to the version i am in. Has that been fixed in 6?
Thank you so much.A cut is a cut & a dissolve is a disolve, and not just anybody with a system is a pro.
Warren Eig
April 2, 2008 at 12:11 amStill exists in version 6.
Warren
Warren Eig
Larry Asbell
April 2, 2008 at 1:34 amThe message about mismatch may come because without dragging the sequence to the ETT window it defaults to trying to lay the contents of the viewer window to tape. Now that’s real logical!
It seems that everyone learning FCP can’t make Edit to Tape work at first and needs to be pointed to the non-intuitive “right way” to do it.
