Activity Forums Apple Final Cut Pro Legacy DVCProHD to a analog HD monitor via 1394
  • DVCProHD to a analog HD monitor via 1394
    Posted by Rick Kz on January 10, 2006 at 8:25 pm
    so you have your edit system of choice, you capture your DVCProHD material thru your firewire port and you would like to monitor it on your existing HD monitor with either analog component HD or HD SDI
    both the convergent and miranda converter box will only accept HDV inputs- anyone seen any other solutions? thanks in advance
    Walter Biscardi replied 20 years, 8 months ago 3 Members · 3 Replies
  • Shane Ross
    January 10, 2006 at 9:38 pm
    Route thru your 1200HD deck. That is the ONLY way to view via firewire. All other solutions require either an HD capture card (optimal) or to route a signal from a DVI connection from your graphics card to a DVI>HD/SDI converter box using Digital Cinema Desktop (less than optimal).
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Rick Kz
    January 10, 2006 at 11:23 pm
    the bummer side of this solution is that the 1200A with the input set to 1394, the HD-sdi and analog component HD output flickers like crazy
    panasonic notes this in the 1200A docs and, so far, has no plans to fix this
    of course the real solution is a kona card
  • Walter Biscardi
    January 10, 2006 at 11:40 pm
    [rick kz] “of course the real solution is a kona card”
    Yep, that’s what I do. I monitor all HD and DVCPro HD via my Kona 2 card. I love the 1200A, but there are some limitations you need to work with.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
