Activity Forums Apple Final Cut Pro Legacy DVCPROHD timeline to SD MPEG
  • DVCPROHD timeline to SD MPEG
    Posted by Craig Ernst on September 14, 2005 at 5:37 am
    I am trying to export a 55 minute DVCPROHD 720p timeline to Standard Def. MPEG2. Is there anything “special” I need to do in “Compressor” to make this work or can I use a standard 90minute preset to make this happen??? Will it take a long time???
    Craig
    Walter Biscardi replied 21 years ago 3 Members · 2 Replies
  • Shane Ross
    September 14, 2005 at 5:44 am
    The Standard preset should work. It converts the HD material to an SD MPEG 2.
    So far I have compressed DVCPRO HD for the Web…haven’t tried DVD yes.
  • Walter Biscardi
    September 15, 2005 at 12:10 pm
    [Craig Ernst] “Is there anything “special” I need to do in “Compressor” to make this work or can I use a standard 90minute preset to make this happen??? Will it take a long time???”
    Just export a reference Quicktime Movie from FCP, Quit FCP, then use a standard MPEG-2 compressing setting in Compressor and you should be good to go. If you use the Export To Compressor option, it will be VERY slow as FCP stays running in the background.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
