Activity Forums Blackmagic Design DVCProHD Sequence to HDCAM Master
  • DVCProHD Sequence to HDCAM Master
    Posted by Paul Toth on May 6, 2010 at 3:52 pm
    I am trying to output an hour long show that was edited in a DVCProHD 1080 sequence and export to HDCAM master via HD SDI, using the Decklink HD Extreme 3 card… can this be done? So far I have been unable to see any picture or sound on the HDCAM deck.
    Paul
    Kristian Lam replied 16 years, 3 months ago 2 Members · 1 Reply
  • Kristian Lam
    May 8, 2010 at 3:39 am
    Hi Paul,
    More information would be good. Windows (Premiere Pro) or Mac? Either way, you will be able to do it on both platforms.
    Firstly, verify that you have video/audio coming out to a monitor. If that’s the case, then it’s most likely a VTR setting. The HDCAM deck does multiple frame rates in HD so make sure it’s set to the one you’re outputting.
    regards
    Kristian Lam
    Blackmagic Design
