Activity Forums Apple Final Cut Pro Legacy DVCProHD Quicktime
  • DVCProHD Quicktime
    Posted by John Tate on June 29, 2009 at 3:46 pm
    I am about to output a sequence using QuickTime and my output setting is: 29.97 1080i DVCProHD.
    Now the sequence has multiple formats (XDCam and DVCProHD). Will Final Cut automatically output all the footage as DVCProHD format or will I need to Media Manager it as one format before outputting it as a QuickTime?
    Thanks.
    John
    John Fishback
    replied 17 years, 2 months ago
    3 Members · 3 Replies
  • John Tate
    June 29, 2009 at 4:46 pm
    My codec setting for the edit timeline is the DVCProHD setting. So, you are saying that FCP will export everything in that timeline to look like DVCProHD? I’m just trying not to do more than I have too. I really appreciate the reply.
    John
  • Steve Eisen
    June 29, 2009 at 4:48 pm
    Render everything on your timeline (please be patient) and export a QuickTime Movie. If your sequence is set to DVCPro HD, then your file will be DVCPro HD so long to use Current Settings.
    Next time, I would recommend choosing one format for your timeline.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • John Fishback
    June 29, 2009 at 4:52 pm
    If the different clips have the same timebase, rendering will do the trick. Just be sure your render preferences are set to Best. If the clips have different timebases (23.976, 29.97, etc.) those conversions need to be done in Compressor. FCP will butcher the conversion in a render.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
