Activity Forums Adobe Premiere Pro DVCProHD on Premier CS3
  • DVCProHD on Premier CS3
    Posted by Adam Mercado on December 15, 2008 at 5:15 pm
    Hi, is anyone cutting DVCProHD footage on Premier? What is your workflow for that, because it seems the DVCPro codecs are only installed with FinalCutPro which sounds awfully lame to me.
    Is there any way to do this or are Apple and Panasonic exclusive bed partners?
    cheers
    mm66
    Adam Mercado
    Influxx Media Production
    Motion Graphics & Video Post Production
    Fullerton, CA
    Adam Mercado replied 17 years, 9 months ago 3 Members · 7 Replies
  • 7 Replies
  • Vince Becquiot
    December 15, 2008 at 5:31 pm
    Are you on a Mac ?
    The first update to CS3 brought DVC Pro HD support (from P2); You’ll know it’s there when the presets show up in your project options.
    So, make sure you update first if it’s a new install.
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    San Francisco – Bay Area
  • David Keslick
    December 15, 2008 at 6:12 pm
    You may want to check out DVfilm decoder. It enables your PC to open dvcprohd .mov files. If you also need to render out to dvcprohd than DVfilm encoder pro does both.
    Hope this helps,
    Dave
  • Adam Mercado
    December 15, 2008 at 7:04 pm
    I am on a Mac, i just checked for updates and lo and behold, every CS3 app had some kind of update. Not sure why Updater had not notified me of this. Crazy.
    Thanks much for the tip!
    mm66
    Adam Mercado
    Fullerton, CA
  • Adam Mercado
    December 15, 2008 at 7:05 pm
    Great tip thanks David
    will check it out
    -Adam
    Adam Mercado
    Fullerton, CA
  • Adam Mercado
    December 15, 2008 at 7:20 pm
    So I updated Premier to 3.2 and the presets for DVCPro are there. Great.
    However I cannot preview clips in QuickTime, the DVCPro codec is not installed to the system library. I take it the codec is built into Premier somehow. Is there no way to get the DVCPro codec into the system? I guess I would need to import footage and transcode to P-JPEG for preview which seems like a bit of a pain.
    cheers
    mm66
    Adam Mercado
    Fullerton, CA
  • Vince Becquiot
    December 15, 2008 at 7:24 pm
    Are these native P2 files ?
    If so, you can download the P2 viewer from Panasonic. Make sure you follow the instructions, installing the driver first.
    Vince Becquiot
    Director | Editor
    Kaptis Studios
  • Adam Mercado
    December 15, 2008 at 7:54 pm
    No, i believe this footage is pre-P2 era. It maybe possibly transcoded from another hardware system
    thanks for the P2 player link though.
    adam
    Adam Mercado
    Fullerton, CA
