Activity Forums Panasonic Cameras DVCProHD in PAL land
  • DVCProHD in PAL land
    Posted by Matthias Kranich on April 9, 2005 at 1:34 am
    Excuse my ignorance and poor English.
    I was thinking about the following:
    If DVCProHD 1080 is achieved by multiplying DVCPro by 4 you get a total pixel count of 1’382’400. So if a future “PAL” DVCProHD is made the same way you’d get 1’658’880 pixels. That means 1080p25 would give you 276’480 pixels more than 30p/24p. Is this correct or nonsense? Man I should try to get some sleep. It’s 3.30 in the mornig here.. counting sheep is so boring, I rather count pixels ,-)
    Matthias
    Guy Barwood replied 21 years, 5 months ago 6 Members · 6 Replies
  • Gabriel
    April 9, 2005 at 4:49 am
    Same line/pixel count. Only difference is 50/25 for PAL compatibility over 24/30/60for NTSC world.
    Gabriel Costache
    Sales Engineer
    Panasonic NZ Ltd
  • Guy Barwood
    April 9, 2005 at 6:43 am
    [Gabriel] “Same line/pixel count. Only difference is 50/25 for PAL compatibility over 24/30/60for NTSC world. “
    That would be 24/25/50 for PAL wouldn’t it, just as much as 24/30/60 for NTSC.
    ie neither PAL or NTSC is 24fps, so I would assume if there are PAL and NTSC models (as such), then 24fps will still be available in both versions.
    You wouldn’t keep 24fps from PAL country models would you?
  • Morten
    April 9, 2005 at 9:51 am
    The DVX100A does not have 24P in Pal land
    – No Parking Production –
    FCP 4.5, Dual G5, X-Raid
  • Toke
    April 9, 2005 at 10:35 am
    It’s not just multiplying the pixels.
    But the datarates do multiply, so you need very little
    changes to the hardware, just building more pipes.
  • Misha Aranyshev
    April 9, 2005 at 10:43 am
    There will be two versions – 24/30/60 and 25/50. This is probably because it is easier to get 25 frames from 50 Hz CCD than from 60Hz CCD. We get it later, pay more and it comes with less features. Some things never change.
  • Guy Barwood
    April 9, 2005 at 11:51 am
    [mishka] “There will be two versions – 24/30/60 and 25/50”
    Seriously? That’s just plain beyond me, how they can expecte people to use 25fps for 24fps productions when the camera is clearly capable of native 24fps. If this is the case that is just plain nasty.
