Activity Forums Apple Final Cut Pro Legacy DVCProHD Frame Rate Converter
  • DVCProHD Frame Rate Converter
    Posted by Quinn Costello on February 26, 2010 at 1:07 am
    Hi-
    I’m trying to use the DVCProHD Frame Rate Converter to transfer DVCProHD 59.94 clips to ProRes 24. However, when I go to the tools menu nothing happens when I select the DVCProHD Frame Rate Converter even though it shows up in the menu. I’ve been told that it’s in the Extras folder in my FCS disc but it doesn’t seem to be there. Any ideas?
    I’m running FCP 6.0.5.
    Thanks for all the help.
    Shane Ross replied 16 years, 6 months ago 3 Members · 2 Replies
  • Jeremy Garchow
    February 26, 2010 at 1:22 am
    [Quinn Costello] “I’m trying to use the DVCProHD Frame Rate Converter to transfer DVCProHD 59.94 clips to ProRes 24”
    Unfortunately, it doesn’t work that way.
    Is your footage 59.94 or did you shoot 24p with pulldown (720p24 mode on camera, not 24pN).
    Jeremy
  • Shane Ross
    February 26, 2010 at 2:51 am
    The FRC converts 59.94 to 29.97 or 23.98…it doesn’t convert to ProRes.
    Shane
