Activity Forums AJA Video Systems DVCproHD down convert
  • DVCproHD down convert
    Posted by Peter Mcauley on May 11, 2005 at 9:54 pm
    I’m trying to playback a dvcprohd clip and have it display on my SD SDI monitor. I’m only getting a still frame frame that updates to the next still frame after I press stop. It’s showing up letterbox which is what I would expect but it will not display moving on the monitor only in FCP viewer. Can anyone help me sort this out.
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.3.8
    FCP 4.5 HD
    QT 6.5.2
    Kona 2 v1.1 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
    Baljit Deo replied 21 years, 4 months ago 3 Members · 2 Replies
  • Jared Picune
    May 11, 2005 at 10:03 pm
    Make sure you choose the correct FCP easy setup. It should be something like AJA Kona 2 720 24 DVCPOHD, depending on your frame rate and how you are set up.
    Jared
    Idea Spring Editing, Inc.
    Denver Final Cut Pro UG
  • Baljit Deo
    May 12, 2005 at 6:07 am
    Also in your Kona Control panel, ensure your outout is set to down convert. And the appropiate signal is selected. i.e primary or seconday and that the downcovert is assigned. You can also set up for your monitor for letterbox or anamorphic if you have a 16:9 monitor.
    Hope this helps.
    Bal
    Kona 2
    Aja IO
    FCP 4.5
    G5 DUEL 2.5GHz
    http://www.st-life.com
