Activity Forums Apple Final Cut Pro Legacy DVCPROHD Deck problem — NO Video in FCP
  • DVCPROHD Deck problem — NO Video in FCP
    Posted by Brian Pitt on February 17, 2011 at 3:49 pm
    I rented an AJ-HD1400 because I have some source tapes that I need to digitize. Tapes were shot DVCPROHD 720 30p.
    I have the deck hooked up to FCP and all of the Audio/Video settings set up accordingly. When I go to the log and capture window, I see the timecode, but there is no video preview – it just says Preview Disabled and is showing color bars.
    If I try logging a clip, it lets me log it, but when I go to batch capture it doesn’t do anything. Same thing if I try capture now…
    I usually only deal with DV and HDV when using the log and capture function. Is there something I’m missing with DVCPROHD???
    Brian
    Brian Deviteri replied 15 years, 7 months ago 3 Members · 8 Replies
  • 8 Replies
  • Brian Pitt
    February 17, 2011 at 4:09 pm
    Okay….I think I’m getting close. If I change the Capture/Input to DV NTSC, I now get a signal in Final Cut. But I need this captured as DVCPROHD. This leads me to believe there is a setting in the deck that is downconverting to SD through firewire. I am not familiar with this deck and the rental didn’t come with a user manual. Can anybody help me out?
    Brian
  • Andrew Rendell
    February 17, 2011 at 4:40 pm
    Google is my friend: ftp://ftp.panasonic.com/pub/panasonic/drivers/PBTS/manuals/OM_AJ-HD1400.pdf
    It does sound like the firewire setting isn’t right – hopefully if you download that manual the information you need will be in there.
  • Brian Pitt
    February 17, 2011 at 4:47 pm
    I actually just found that manual about 5 minutes before you posted this, but I’m still not having any luck…
    Brian
  • Andrew Rendell
    February 17, 2011 at 4:58 pm
    It does look a bit of a ‘mare. Looks like you’ve got to set output data format separately from system freq….. remember to unplug the firewire cable each time you make a change, then plug it in again to see if you’ve nailed it. Good luck, I’m sure you’ll get there eventually, it’s mainly about being very careful and methodical.
  • Brian Pitt
    February 17, 2011 at 5:01 pm
    Wow….I’m an idiot. I fixed the problem the first time I tried. I just didn’t turn the deck off and back on. THANK YOU for the suggestion. Everything seems good now. Thanks again!!!
    Brian
  • Brian Pitt
    February 17, 2011 at 5:04 pm
    HAH! Nevermind. I captured and it’s still capturing SD. Dammit!!!!
    Brian
  • Brian Pitt
    February 17, 2011 at 5:44 pm
    I found the problem. If anyone is having this issue. Go and change option 894 in the menu to HD. They don’t make it too easy to find…. 🙂
    Brian
  • Brian Deviteri
    February 17, 2011 at 7:23 pm
    “IF” you run into any further issues when capturing, check your tri-level sync settings. That deck’s “freerun” isn’t exactly dependable all the time…
