Activity Forums Apple Final Cut Pro Legacy DVCPROHD deck not playing nice…..
  • DVCPROHD deck not playing nice…..
    Posted by Hector Candleleven on October 17, 2007 at 1:40 pm
    Basically, FCP is seeing my deck in local mode even thou I have the Deck on remote. I’m using the Kona LH card with the SDI connections. I’m connecting the SDI’s from the deck to the 3 SDI’s on the Kona card. I’m wondering if that might be the issue. I’ve also tried just about every setting in the AJA control panel with no sucess.
    Would I lose any quality from the image if I just scraped the whole SDI business and used the Firewire cable?
    Thanks in advance.
    Hector Candleleven replied 18 years, 11 months ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    October 17, 2007 at 1:45 pm
    [Hector] “Would I lose any quality from the image if I just scraped the whole SDI business and used the Firewire cable?
    If your source tape is DV and your timeline and edit are in DV, then the quality will be the same if you capture via FW,
  • Walter Biscardi
    October 17, 2007 at 1:46 pm
    [Hector] “I’m using the Kona LH card with the SDI connections. I’m connecting the SDI’s from the deck to the 3 SDI’s on the Kona card.”
    What do you mean the Three SDI’s? SDI is a single cable with video and audio embedded. Component is three cables with video only broken up into RGB.
    [Hector] “Basically, FCP is seeing my deck in local mode even thou I have the Deck on remote.”
    What Easy Setup are you using?
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Hector Candleleven
    October 17, 2007 at 1:58 pm
    RS 422, duh!!! Haven’t had my coffee yet. Thanks anyway.
