Activity Forums Apple Final Cut Pro Legacy DVCPROHD 1080i60 footage from HVX200 – FCP says it is 1080p30 and it looks like image is melting
  • DVCPROHD 1080i60 footage from HVX200 – FCP says it is 1080p30 and it looks like image is melting
    Posted by Crescent Diamond on November 5, 2011 at 7:55 pm
    Hi. My DP shot in 1080i60 on the HVX and when I transferred it to FCP, it is read as 1080p30. When it plays in the viewer, it looks terrible, like the screen is melting. I did some research and figured out that the camera was set to “film mode” which I guess FCP can not process at 1080i60, and sees it as 1080p30. When I made the sequence settings at 1080i60 and add fields (upper or lower), it looks fine in playback on the canvas.
    My question is, should I just edit my film this way and finish at 1080i60, or should so something else before editing? I am also planning on adding stills, old video (interlaced) and original digital animation.
    I am using FCP 6 on my MacBook Pro.
    Thanks, Crescent D.
    Chris Tompkins replied 14 years, 10 months ago 2 Members · 1 Reply
  • Chris Tompkins
    November 6, 2011 at 11:39 am
    What are all the specs in the browser on the clips?
    Under 1080i the video can be:
    1080i – 60i (AWKA 29.97) – this will be Upper Fields
    1080i – 30p
    1080i – 24p
    1080i – 24pa
    1080i – 24pn
    Chris Tompkins
    Video Atlanta LLC
