Activity › Forums › Compression Techniques › DVCPro50 squished by compressor mpeg4
  • DVCPro50 squished by compressor mpeg4
    Posted by Jonathon Fulton on October 1, 2008 at 7:42 pm
    I have some footage shot on an HVX200 – DVCPro 50 at 480i. I exported from Final Cut Pro 6.04 using export as QT movie. Then opened that in Compressor.
    I tried Compressor setting of Mpeg-4 but the footage has come out squished.
    Why would that be when the frame size is set to 100% of source and the pixel aspect is set to default for size?
    Daniel Low replied 18 years ago 2 Members · 1 Reply
  • Daniel Low
    October 1, 2008 at 9:01 pm
    DV uses non-square pixels, MP4 uses square pixels. Solution, set the output frame size aspect ratio to match the source aspect ratio, not the source frame size,
    I.e. 720×480 non-square source = 640×480 square output.
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
