Activity › Forums › Apple Final Cut Pro Legacy › DVCPRO50 Preset?
  • DVCPRO50 Preset?
    Posted by David Roth weiss on May 7, 2006 at 3:21 am
    There is no DVCPro50 NTSC setup in my vast array of Easy Setup presets, so I decided to forge ahead and upgrade to the 5.1 universal binary version of FCP hoping that there might be a preset there, since those disks arrived earlier this week. Does anyone know if there is a DVCPro50 NTSC preset on the new version???
    THNX,
    DRW
    David Roth weiss replied 20 years, 4 months ago 2 Members · 2 Replies
  • John Pale
    May 7, 2006 at 5:39 am
    They are there with mine…but they are simply called DV50
  • David Roth weiss
    May 7, 2006 at 9:28 am
    Thanks John,
    Wierd that the PAL presets are labeled as DVCPro50 while the NTSC presets are labeled as DV50…
    And, even worse, I can’t capture anything via firewire that stays in sync.
    DRW
