Activity Forums Apple Final Cut Pro Legacy DVCPro50 24p Normal > Cinema Tools > FCP. Right, wrong?
  • DVCPro50 24p Normal > Cinema Tools > FCP. Right, wrong?
    Posted by Don Fito on May 17, 2005 at 7:16 pm
    Hello,
    I’ve read a lot but never done it. I’m capturing DVCPro50 shot with an AJ-SDX900 at 24 p Normal. I’m using an AJ-SD93 over FieWire to go into FCP HD.
    This is my workflow:
    1. I’m capturing as normal 29.97 DVCPRo50 footage, anamorphic.
    2. In CinemaTools I will (haven’t done it yet) do a Rev Telecine (lots of choices on the dialog box). I’ll conform it here to 23.98, make a new file, smaller.
    3. Import into FCP HD and edit on a 23.98 timeline
    Let me know your thoughts.
    Cheers
    (I’m already capturing)
    Don Fito replied 21 years, 4 months ago 3 Members · 5 Replies
  • Matthd
    May 17, 2005 at 7:37 pm
    I’ve done that on many features, (usually HDCam 23.98 that’s down-converted to DVCam 29.97) and my on-lines have all gone very smoothly. It’s a great workflow!
    Matt Smith
    HDFilmout / E3Media Group
    Los Angeles
  • Don Greening
    May 17, 2005 at 7:43 pm
    The link below will explain the differences in capturing 24p and 24pA and what your capturing presets within FCP should be for the different situations. You need to use Cinema Tools to remove the pulldown with normal 24p and then edit in a 23.98 timeline. Sounds like you’re on the right track.
    https://www.kenstone.net/fcp_homepage/24p_in_FCP_nattress.html
    – Don
  • Don Fito
    May 17, 2005 at 8:23 pm
    Thanks Don, this is where I started with Nattress article.
  • Don Fito
    May 17, 2005 at 8:27 pm
    Thanks to both Matt and Don for the vote of confidence. I
  • Don Fito
    May 17, 2005 at 9:22 pm
    Thanks Matt. Now, have you used Cinema Tools? I don
